plt3DICurve GetShadowTransparent
Gets whether the shadow under the curve is transparent.
plt3DICurve_handle GetShadowTransparent flag
HyperWorks Tcl Query
flag
Returns true, if the shadow is transparent, otherwise false.
To check if the shadow under an existing curve is transparent:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName AddCurveGroup
myClientName GetCurveGroupHandle myGroupName 1
myGroupName GetCurveHandle myCurveName 1
myCurveName GetShadowTranparent true
None.
