plt3DICurveGroup GetHighlighted
Returns the curve’s highlight state.
plt3DICurveGroup_handle GetHighlighted
HyperWorks Tcl Query
- True
- Curve is visible.
- False
- Curve is not visible.
None.
View new features for HyperWorks Desktop 2020.1.
Adds a new curve to the curve group.
Copies a curve to the clipboard.
Gets the color of the curve group.
Gets the handle of a particular curve in the group.
Gets whether or not the curve is displayed in the legend.
Gets the curve group’s index.
Finds the math reference of the object.
Gets a named meta-data value previously associated with the curve group.
Gets the current number of curves in the curve group.
Gets the curve’s visibility state.
Removes a curve from the curve group.
Sets the color of the curve group.
Sets whether or not the curve is displayed in the legend.
Sets the curve’s highlight state.
Associates a named meta-data value with the curve.
Sets the auto curve visibility state.
ON THIS PAGE
None.
ON THIS PAGE
