plt3DILegend GetHighlighted
Gets whether the legend is highlighted.
plt3DILegend_handle GetHighlighted
HyperWorks Tcl Query
The appearance of a highlighted legend will change to indicate that it is active or has been picked through the GUI. To see this effect, alter the highlighted flag to cause a redraw of the client.
Returns true or false.
To check if the legend is highlighted:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetLegendHandle myLegendName
myLegendName GetHighlighted
None.
