plt3DIPlot SetIncludeAxesInFit
Sets whether the axes box is kept visible by a fit operation.
plt3DIPlot_handle SetIncludeAxesInFit enabled
HyperWorks Tcl Query
In box axis mode, by default, the axes box is included in bounding box calculations, so as to keep it visibile when a fit operation occurs. Turning this flag off causes the plot to appear larger after a fit operation, but parts of the axes box may not be visible.
enabled
Keep axes visible, true or false.
To increase the size of the plot, at the potential expense of the axes:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetSurfaceHandle mySurfaceName
myClientName SetIncludeAxesInFit false
myClientName Draw
Error
None.
