plt3DISurface GetColor
Gets the color of the surface.
plt3DISurface_handle GetColor
HyperWorks Tcl Query
The string returned will be either a color name (if the RGB values of the color match a name), an index (if the value matches one of the standard palette of colors), or a set of three RGB values. Returns a color identifier string.
To get the color of an existing surface:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetSurfaceHandle mySurfaceName 1
mySurfaceName GetColor
Success (0) or an error code.
