plt3DISurface GetMetaData
Gets a named meta-data value previously associated with the surface.
plt3DISurface_handle GetMetaData
HyperWorks Tcl Query
Metadata can be any string or string representation of a number.
Returns a string (the meta-data value).
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetSurfaceHandle mySurfaceName 1
mySurfaceName SetMetaData species narwhale
mySurfaceName GetMetaData species
Returns an empty string if the value is not defined.
