plt3DIWaterfall GetDataSourceHandle
Gets the handle of a particular data source from the waterfall.
plt3DIWaterfall_handle GetDataSourceHandle iSource name
HyperWorks Tcl Query
Waterfalls can be defined by a collection of data sources that are interpreted as matrices and used to generate curves (slices).
iSource
The name of the new handle.
name
The name of data source.
To get the X, Y, Z and W (contour) data source handles from an existing waterfall:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetWaterfallHandle myWaterfallName 1
myWaterfallName GetDataSourceHandle dsX x
myWaterfallName GetDataSourceHandle dsY y
myWaterfallName GetDataSourceHandle dsZ z
myWaterfallName GetDataSourceHandle dsW w
Error
None.
