plt3DIWaterfall RemoveCursor
Removes a cursor from a waterfall.
plt3DIWaterfall_handle RemoveCursor index
HyperWorks Tcl Query
Cursors are objects that can be used to facilitate picking and querying of values from an underlying data object.
index
The index of the cursor to remove (one-based).
To remove a Cursor from an existing waterfall:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetWaterfallHandle myWaterfallName
myWaterfallName RemoveCursor 1
None.
