pltIAnimationCursor GetUseCurveColor
Determines if the color of the animation cursor is the same as the curve it is on.
pltIAnimationCursor_handle GetUseCurveColor
HyperWorks Tcl Query
This command determines if the color of the animation cursor is the same color as the curve it is on. If it is, true is returned. If the cursor is not set to be the same color as the curve it is on, false is returned. If the curve is black, the cursor will be black regardless if GetUseCurveColor is true or false.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot GetAnimationCursorHandle ach;
ach GetUseCurveColor;
Success (a true or false value) or an error message is returned.
Keywords
HyperWorks
Tcl
Animation Cursor
Query
