pltIAxis GetDisplayValue
Gets the display value when the real value is input.
pltIAxis_handle GetDisplayValue real_value
HyperWorks Tcl Query
This command gets the display value when the real value is input. This command only works properly when the axis is scaled in dB20 or dB10.
real_value
The real value that you want to get the corresponding display value of.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot GetVerticalAxisHandle yaxis 1;
yaxis GetDisplayValue 30;
Success (the display value) or an error message is returned.
Keywords
HyperWorks
Tcl
Axis
Query
