pltIBuildPlotsCtrl SelectDataFile
Selects a file to use in build plots mode.
pltIBuildPlotsCtrl_handle SelectDataFile active_file, (post_mode)
HyperWorks Tcl Modify
This command selects a file to use in build plots mode.
- active_file
- The filepath of the file that you want to use.
- (post_mode) (Optional)
- True
- To open the file in post mode (HyperView).
- False
- If you do not want the file to be opened in post mode, input false or nothing (this would keep the file in HyperGraph).
hwi GetSessionHandle sess;
sess GetClientManagerHandle mgr plot;
mgr GetBuildPlotsCtrlHandle build;
build SelectDataFile “C:/demos/mv_hv_hg/plotting/madymo/FORCES” false;
Keywords
HyperWorks
Tcl
Build Plots
Modify
