pltIDrawControl DrawFilledEllipse
Draws a filled ellipse.
pltIDrawControl_handle DrawFilledEllipse ulx, uly, lrx, lry, color
HyperWorks Tcl Modify
Returns 0 = HW_Success or 3 = HW_InvalidHandle.
ulx
X-coordinate of the upper left point of a rectangle into which the ellipse is inscribed.
uly
Y-coordinate of the upper left point of a rectangle into which the ellipse is inscribed.
lrx
X-coordinate of the lower right point of a rectangle into which the ellipse is inscribed.
lry
Y-coordinate of the lower right point of a rectangle into which the ellipse is inscribed.
color
The index of the color to be used (must be non-negative).
To draw an ellipse from (-.5, 1) to (.5, -1) with a color index of 2:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName
myPageName GetWindowHandle myWindowName
myWindowName GetClientHandle myPlotName
myPlotName GetDrawControlHandle myDrawer
myDrawer DrawFilledEllipse -.5 1 .5 -1 2
None.
