pltIExportCtrl SetFilename
Sets the name of a file.
pltIMacro_handle GetFilename filename
HyperWorks Tcl Modify
This command sets the name of the export file. Once a name is assigned, you can export the file.
filename
The filename for the export file. To find the correct format extension for the file, call GetFormatExtension.
hwi GetSessionHandle sess;
sess GetClientManagerHandle pm Plot;
pm GetMacroHandle mh 1;
mh GetExportCtrlHandle ex;
ex SetFilename myfile.txt;
Keywords
HyperWorks
Tcl
Export
Modify
