pltINote SetCoordinateXExpression
Sets the expression for the x value to which the note is attached.
pltINote_handle SetCoordinateXExpression x_expression
HyperWorks Tcl Modify
This method is only available for coordinate notes.
- x_expression
- The expression for the x value to which the note is attached.
Returns success or an error code.
