pltINote SetEmbedded
Sets if the note is embedded on a curve.
pltINote_handle SetEmbedded state
HyperWorks Tcl Modify
This command sets whether the note is embedded on a curve (without a leader line).
state
true
If you want the note to be embedded.
false
If you do not want the note to be embedded.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot GetNoteHandle n1 1;
n1 SetEmbedded true;
Keywords
HyperWorks
Tcl
Note
Modify
