pltIPlot CopyRadialDatum
Copies a radial datum.
pltIPlot_handle CopyRadialDatum datum, append_future
HyperWorks Tcl Modify
This command copies a radical datum based on the user-input datum index. A radical datum is a line that goes around the plot in the polar plot (it looks like a circle in the plot). It is used for comparisons.
datum
The datum index (position in the datum list) that you want to copy.
append_future
true
Indicates the copy is added to a memory.
false
Indicates that the copy is not added to memory. This way, multiple copies can be made and pasted at the same time, rather than copying and pasting each one individually.
Examples
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot CopyRadialDatum 1 true;
Keywords
HyperWorks
Tcl
Polar Plot
Datum
Modify
