pltIPlot CopyVerticalAxis
Copies a vertical axis.
pltIPlot_handle CopyVerticalAxis axis, append_future
HyperWorks Tcl Modify
This command copies a vertical axis based on the user-input axis index.
axis
The axis index (position in the axis list) that you want to copy.
append_future
true
Indicates the copy is added to a memory.
false
Indicates that the copy is not added to memory. This way, multiple copies can be made and pasted at the same time, rather than copying and pasting each one individually.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot CopyVerticalAxis 1 true
Keywords
HyperWorks
Tcl
XY Plot
Modify
