pltIPlot PasteRadicalDatum
Pastes previously copied or cut radical datum lines.
pltIPlot_handle PasteRadicalDatum index
HyperWorks Tcl Modify
This command pastes previously copied or cut radical datum lines into the datum list. A radical datum is a line that goes from the center outward in the polar plot. It is used for comparisons.
index
The index (position number) where you want to insert datum line. PasteRadicalDatum pastes the user-input index and moves the list down one position if it is at or below that index.
hwi OpenStack;
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot PasteRadicalDatum 3;
Keywords
HyperWorks
Tcl
Polar Plots
Datums
Modify
