pltIPlot Recalculate
Forces the plot to regenerate all calculated data and reread all file data. Only curve data that has been modified since the last call to Recalculate is recomputed.
pltIPlot_handle Recalculate
HyperWorks Tcl Query
This method may indirectly get data again for plots other than itself if data in the plot is dependent on data outside of the plot.
Returns success or an error code.
