pltIPlotManager SetUseEvenCycles
Sets the state of the Use Even Cycles option.
pltIPlotManager_handle SetUseEvenCycles state
HyperWorks Tcl Modify
This command sets if Use Even Cycles is on or off. If on, Use Even Cycles makes even cycles when fitting the log axes.
state
A true or false value.
True
When you want Use Even Cycles to be on.
false
When you want the option to be off.
hwi GetSessionHandle sess;
sess GetClientManagerHandle pm Plot;
pm SetUseEvenCycles true;
Keywords
HyperWorks
Tcl
Modify
