pltIVectorComplex SetRequest
Sets the request used by the vector.
pltIVectorComplex_handle SetRequest request
HyperWorks Tcl Modify
Call the Recalculate method on the parent plot object to update the data.
This method is only valid for file vectors.
request
The name of the request used by the vector.
This is dependent on the data file referenced by the vector.
This method only changes the filename.
Success or an error code.
