pltIVectorComplex SetComponent
Sets the component used by the vector.
pltIVectorComplex_handle SetComponent component
HyperWorks Tcl Modify
This method only changes the filename. Call the Recalculate method on the parent plot object to update the data.
This method is only valid for file vectors.
- component
- The name of the component used by the vector. This is dependent on the data file referenced by the vector.
Success or an error code.
