poI3DViewCtrl SetViewMatrix
Sets a 4x4 view matrix orientation for the active window.
poI3DViewCtrl_handle SetViewMatrix view_matrix
HyperView Tcl Modify
This command updates the view orientation matrix of the current active window with the given sixteen float values.
- view_matrix
- The sixteen float values (a 4x4 matrix of space separated float values) which determine the view of the current active model.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
window_handle GetViewControlHandle viewctrl_handle
viewctrl_handle SetViewMatrix “1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1“
puts "View Matrix: [viewctrl_handle GetViewMatrix]"
hwi CloseStack
Error
Returns an error if the view control handle is invalid.
