poIAdvancedQuery SetNumericPrecision
Sets the numeric precision for output values.
advancedQuery_handle SetNumericPrecision precision
HyperView Tcl Modify
This command is used to set the numeric precision to the advanced query.
precision
Accepts the precision number which is ideally an integer value from 0 to 12.
To set the numeric precision to the advanced query:
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule extreme]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetExtreme "TopN 3"
set advQueryID [client AddAdvancedQuery]
client GetAdvancedQueryHandle advancedQuery_handle $advQueryID
advancedQuery_handle AddSimulations "current" "current"
advancedQuery_handle SetQuery "entity.id entity.value"
advancedQuery_handle SetQueryLogic "[rule_handle GetID]"
advancedQuery_handle SetNumericPrecison "5"
advancedQuery_handle GetValueList
hwi CloseStack
This command returns HW_Error, if precision is less than 0.
