poIAdvancedQuery SetQueryLogic
Sets the query logic to the advanced query.
advancedQuery_handle SetQueryLogic rule
HyperView Tcl Modify
This command sets the rule to the advanced query.
rule
The rule ID in the string format.
To set the query logic to the advanced query:
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule extreme]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetExtreme "TopN 3"
set advQueryID [client AddAdvancedQuery]
client GetAdvancedQueryHandle advancedQuery_handle $advQueryID
advancedQuery_handle AddSimulations "current" "current"
advancedQuery_handle SetQuery "entity.id entity.value"
advancedQuery_handle SetQueryLogic "[rule_handle GetID]"
hwi CloseStack
This command returns HW_Error, if there is no rule ID available in the advanced query.
