poIAdvancedQuery SetSearchOption
Sets the search options status to the advanced query.
advancedQuery_handle SetSearchOption name state
HyperView Tcl Modify
[SetSearchOption "simulation" true]
will result in the output being displayed per simulation basis.[SetSearchOption "component" true]
will result in the output being displayed per component.
- name
- Valid name options: "simulation" or "component".
- state
- Valid options: true or false.
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule extreme]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetExtreme "TopN 3"
set advQueryID [client AddAdvancedQuery]
client GetAdvancedQueryHandle advancedQuery_handle $advQueryID
advancedQuery_handle AddSimulations "current" "current"
advancedQuery_handle SetQuery "entity.id entity.value"
advancedQuery_handle SetQueryLogic "[rule_handle GetID]"
advancedQuery_handle SetSearchOption "simulation" true
advancedQuery_handle SetSearchOption "component" true
advancedQuery_handle GetValueList
hwi CloseStack
This command returns HW_Error
, if invalid strings are passed to the
argument name.
