poIAssembly GetPool
Gets the pool name in which the assembly exists.
assem_handle GetPool
HyperView Tcl Query
This command retrieves the pool name in which the assembly exists.
To get the pool name of an assembly:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
# Assuming that the model contains an assembly whose id is 1
model_handle GetAssemblyHandle assem_handle 1
hwi CloseStack
None.
