poIAssembly SetIDVisibility
Sets the display state of the assembly ID (on or off).
assem_handle SetIDVisibility state
HyperView Tcl Modify
This command sets the display state of the assembly ID (on or off).
state
True or False.
To turn on the ID visibility of an assembly with an ID of 1:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetAssemblyHandle assem_handle 1
assem_handle SetIDVisibility true
hwi CloseStack
Error
Returns an non-zero value if an error occurs.
