poIAssembly SetParentID
Sets/changes the parent of an assembly to a different parent ID.
assem_handle SetParentID id
HyperView Tcl Modify
This command sets/changes the parent of an assembly to a different parent ID.
- id
- The new parent assembly ID.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetAssemblyHandle assem_handle 2
assem_handle SetParentID 3
hwi CloseStack
Error
Returns an non-zero value if an error occurs.
