SetEntity
Sets the entity information for the best view.
bestview_handle SetEntity type loc_string
HyperView Tcl Modify
This command sets the entity information for the best view.
type
The type of entity used (element, node, or component).
loc_string
A string to locate the entity, poolname, and ID.
Tip: Combinations can be used (example: {Node 123}).
To set the entity information for the best view:
bestview_handle SetEntity element {Shell 1951613}
bestview_handle SetEntity node {Node 3012254}
Returns success (0) or an error code.
