SetHiddenSet
Sets the set to be used for hiding entities.
bestview_handle SetHiddenSet loc_string
HyperView Tcl Modify
global
, globallocation
contour
, and transparency
.Other modes of best view will ignore the hidden set settings.
- loc_string
- A string to locate the set, typically a pool/ID combination (example: {User_Set 1}).
bestview_handle SetHiddenSet {User_Set 5}
Returns success (0) or an error code.
