SetViewMode
Sets the view mode to be used for the best view.
bestview_handle SetViewMode mode
HyperView Tcl Modify
This command sets the view mode to be used for the best view.
- mode
- The view mode to be used. Valid options include:
global
- Shows all of the best views simultaneously and the entire model together in isometric view. SetHiddenSet can be used to hide a few components of your choice.
globalcomponents
- Shows all of the best views and their parent components together, with everything else transparent in isometric view.
globalregions
- Shows all of the best views and elements within a region size attached to the best view entities, with everything else transparent in isometric view.
globalspheres
- Shows all of the best views and elements within a sphere around the best view entities, with everything else transparent in isometric view.
globalallocation
- Shows only the best view on the current handle with the entire model visible in
isometric view, except the entities inside the hidden set. This is a single best
view version of the
global
view mode. componenttransparency
- Shows only the best view on the current handle with only its parent component
visible in isometric view, everything else in the model in shown in transparency.
This is a single best view version of
globalcomponents
view mode. isolatecomponent
- Shows only the best view on the current handle with only its parent component visible in a view normal to the current orientation of the element, everything else in the model is hidden.
entityzoom
visible in a zoomed view normal to the current orientation of the element,
everything else in the model is hidden. This is a zoomed in version of
isolatecomponent
view mode. contour
- Shows only one best view on the current handle with the entire model visible in
a view normal to the current orientation of the element. This is a localized
version of the
globallocation
view mode. transparency
- Shows only one best view on the current handle with the spherical region around
entity visible, in a view normal to the current orientation of the element. This
is a single view version of
globalspheres
view mode.
Note: The default view mode isglobal
hwi GetActiveClientHandle client
client AddBestView
client GetBestViewHandle bestview_handle1 1
bestview_handle1 SetEntity node 22460
client GetBestViewHandle bestview_handle2 [client AddBestView]
bestview_handle2 SetEntity node 22568
bestview_handle1 SetViewMode globalcomponents
bestview_handle1 ActivateView
a Draw true
Returns success (0) or an error code.
