poIComponent ApplyDefaults
Sets component material to default values.
Important: Please note that this command has been deprecated and therefore is not recommended for use. See the poIPart Class for an alternative command that can be used.
poIComponent_handle ApplyDefaults
HyperView Tcl Query
This command sets component material to default values.
Error
Returns 0 if successful, otherwise an error code.
