poIComponent GetLabel
Gets the component's label.
poIComponent_handle GetLabel
HyperView Tcl Query
This command returns the component's label.
Error
Returns the component label, or zero if an error occurs.
View new features for HyperWorks Desktop 2020.1.
Gets the current complex filter for the current animation mode.
Gets the list of the available complex filters.
Sets the current complex filter for the current animation mode.
Sets the current result filter to the default state.
Sets component material to default values.
Gets the assembly ID of a component.
Gets the component auto color index.
Gets a list of the all child components.
Gets the component color index.
Gets the component's ID.
Gets the component display option setting.
Gets a list of component display modes.
Gets the component's material index.
Gets the component’s mesh mode.
Gets the number of child components.
Gets the component's polygon mode.
Gets the component's tracing mode.
Gets the translation vector in the global coordinate system.
Gets the component's type string.
Gets the component’s visibility.
Sets the assembly ID of a component.
Sets the component’s auto color index.
Sets the component’s color index.
Sets the component's display mode.
Sets the component’s label.
Sets the component's material index.
Sets the component’s mesh mode.
Sets the component’s polygon mode.
Sets the component’s tracing mode.
Translates a component by the vector given.
Sets the component’s visibility.
ON THIS PAGE
HyperView Tcl Query
ON THIS PAGE
