poIComponent GetMaterial
Gets the component's material index.
Important: Please note that this command has been deprecated and therefore is not recommended for use. See the poIPart Class for an alternative command that can be used.
poIComponent_handle GetMaterial
HyperView Tcl Query
This command returns the component's material index.
Error
Returns the component material index, or zero if an error occurs.
