poIComponent GetMeshMode
Gets the component’s mesh mode.
Important: Please note that this command has been deprecated and therefore is not recommended for use. See the poIPart Class for an alternative command that can be used.
poIComponent_handle GetMeshMode
HyperView Tcl Query
This command returns the component’s mesh mode.
Error
Returns the mesh mode: edges, features, meshlines, or none.
