poIComponent GetPolygonMode
Gets the component's polygon mode.
Important: Please note that this command has been deprecated and therefore is not recommended for use. See the poIPart Class for an alternative command that can be used.
poIComponent_handle GetPolygonMode
HyperView Tcl Query
This command returns the component's polygon mode.
Error
Returns the polygon mode: transparent, opaque, or wireframe.
