poIComponent GetVisibility
Gets the component’s visibility.
Important: Please note that this command has been deprecated and therefore is not recommended for use. See the poIPart Class for an alternative command that can be used.
poIComponent_handle GetVisibility
HyperView Tcl Query
This command returns the component’s visibility.
Error
Returns true if the component is visible, or false if the component is not visible.
