poIComponent SetAutoColor
Sets the component’s auto color index.
Important: Please note that this command has been deprecated and therefore is not recommended for use. See the poIPart Class for an alternative command that can be used.
poIComponent_handle SetAutoColor index
HyperView Tcl Modify
This command sets the component’s auto color index.
index
The color index.
Error
Returns 0 if successful, otherwise an error code.
