poIComponent SetLabel
Sets the component’s label.
Important: Please note that this command has been deprecated and therefore is not recommended for use. See the poIPart Class for an alternative command that can be used.
poIComponent_handle SetLabel name
HyperView Tcl Modify
This command sets the component’s label.
name
The ASCII label.
Error
Returns 0 if successful, otherwise an error code.
