poIComponent SetVisibility
Sets the component’s visibility.
Important: Please note that this command has been deprecated and therefore is not recommended for use. See the poIPart Class for an alternative command that can be used.
poIComponent_handle SetVisibility state
HyperView Tcl Modify
This command sets the component’s visibility.
state
True
If visible.
False
If not visible.
Error
Returns 0 if successful, otherwise an error code.
