poIContourCtrl GetIgnoredFlippedNormal
Gets the state of the "Ignore Flipped Normal" option set for the feature angle average.
contour_handle GetIgnoreFlippedNormal
HyperView Tcl Query
This command returns the state of the "Ignore Flipped Normal" option set for the feature angle average.
To get the "Ignore Flipped Normal" state in contour:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetContourCtrlHandle contour_handle
# Get the Ignore Flipped Normal state
if {[contour_handle GetFeatureAngleAverageEnableState] == true  } {
set flipped_normal [contour_handle GetIgnoreFlippedNormal]
hwi CloseStack
Error
Returns a Boolean value (True or False).
