poIContourCtrl GetMultiplier
Retrieves the multiplication factor for the current contoured data type.
poIContourCtrl_handle GetMultiplier
HyperView Tcl Query
This command returns the multiplier for the applied contour plot (for example: Stress, Velocity, etc.).
To get the multiplication factor for the data type “Effective plastic strain” in a contour plot:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetContourCtrlHandle contour_handle
contour_handle SetDataType ”Effective plastic strain”
set m_factor [contour_handle GetMultiplier]
hwi CloseStack
None.
