poIContourCtrl GetShowMidsideNodeResults
Gets the state of the "Show Midside Node Results" option for the contour control.
contour_handle GetShowMidsideNodeResults
HyperView Tcl Query
This command returns the state of the Show Midside Node Results option for the contour control.
To get the state of the "Show Midside Node Results" option for contour:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetContourCtrlHandle contour_handle
# Get the Show Mid-side Node Results
set state [contour_handle GetShowMidsideNodeResults]
hwi CloseStack
Error
A bool should always be returned.
