poIContourCtrl GetValueFilterEnableState
Gets the state of the contour value filter.
contour_handle GetValueFilterEnableState
HyperView Tcl Query
This command retrieves the value filter state used for the contour. The scale factor may have negative values.
To get the value filter state for a contour:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetContourCtrlHandle contour_handle
# Get the value filter state
set state [contour_handle GetValueFilterEnableState]
hwi CloseStack
Error
Always returns a boolean value.
