poIContourCtrl IsMultipleLayer
Checks to see if the Top/Bottom mode is enabled in the contour controller.
poIContourCtrl_handle bool IsMultipleLayer
HyperView Tcl Query
This command checks to see if the Top/Bottom layer mode is enabled in the contour controller (True/False).
Error
Returns True if enabled, or False if disabled.
