poIContourCtrl SetAverageColor
Sets the averaging state for element results.
poIContourCtrl_handle SetAverageColor enable
HyperView Tcl Modify
This command sets the averaging state for element results. When enabled, elemental colors are averaged to nodes (color per vertex).
Note: Color averaging applies only to elemental values. Enabling averaging has no affect on values reported.
enable
Set to true to enable color per vertex, or false to disable color averaging.
Error
Returns 0 if successful, otherwise an error code.
