poIContourCtrl SetDiscreteColor
Sets the discrete color mode for node-based coloring.
poIContourCtrl_handle SetDiscreteColor enable
HyperView Tcl Modify
This command sets the discrete color mode for node-based coloring.
Note: This option is valid only for nodal, node-on-element, or averaged elemental data.
enable
Set to true for discrete contour coloring, or false for blended RGB contour coloring.
Error
Returns 0 if successful, otherwise an error code.
