poIContourCtrl SetSelectionSet
Sets the selected entities to be used by the contour control.
poIContourCtrl_handle SetSelectionSet set_id
HyperView Tcl Modify
This command specifies the selected entities to be used by the contour control.
- set_id
- The set ID.
Error
Returns 0 if successful, otherwise an error code.
