poIContourCtrl SetThresholdMaxEnableState
Sets the threshold maximum enable state value of a contour (true/false).
poIContourCtrl_handle SetThresholdMaxEnableState value
HyperView Tcl Modify
This command sets the threshold maximum enable state value of a contour (true/false).
- value
- True/false.
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myModelName GetResultCtrlHandle myResultName
myResultName GetContourCtrlHandle myContourName
myContourName SetThresholdMaxEnableState true
Error
Returns 0 if successful, or an error code (HW_InvalidHandle) if the handle used to invoke the method is no longer valid.
